Moates Burn2 not detecting!!
Old Oct 8, 2022 | 12:41 PM
charlielachance's Avatar
Default Moates Burn2 not detecting!!
I recently purchased a Moates Burn2. Plugged it in and burned a map onto my chip just fine. After several more successful burns I took a break. After coming back a few hours later i plug in my burn2 and open flash n burn and it says no burner detected. I have tried everything i could find to fix this including COM settings, swapped usb cable, driver reinstalls and even pulling the casing off to make sure all the circuit solders look intact. I’m at a loss and don’t know why it randomly started not detecting after it worked perfectly fine an hour before. Also doesn’t work on other laptops and pcs. Please help
Old Oct 10, 2022 | 05:18 AM
theYBLEGAL's Avatar
Loved
Default Re: Moates Burn2 not detecting!!
Check com port # in device manager to make sure PC is seeing it?
Make sure baud rate is correct?
Run FlashNBurn as administrator?
Dcardsrule
Nov 11, 2012 12:23 AM
kyden
Engine Management and Tuning
Sep 24, 2011 06:39 AM
user 93082343
Mar 11, 2009 10:17 PM
icon_race_eg
Feb 2, 2004 11:22 PM
