tps calibration issue
i have a k swap mr2 and ive sorted my problem im having with no start to my tps because when i go to calibrate my tps and press read it reads 40% at no throttle and 60% at full throttle, ive tried moving the sensor around on the tb and the lowest i can get it is 32% and full thottle stays the same at 60%, could my brand new tps be faulty... (its a dualast so i wouldnt doubt it)... and the way i figured out that this what the problem is because when i try starting it it would just crank and spudder like it was trying to start and i made sure i was getting spark and i was and everytime i would pull the spark plugs they would be covered is gas, so i tried starting it with the thottle cracked open and it fired right (at like 3k rpm)... thanks
Desert_Rat
May 28, 2018 07:34 AM
