Getting a cel code 6 but the sensor is functional in Tunerview
Old Sep 9, 2022 | 03:44 PM
Thomas Allred's Avatar
Default Getting a cel code 6 but the sensor is functional in Tunerview
I have a 95 Honda accord with a manual h22a swap p28 ecu chipped I use ectune for cobra rtp because that's the board I had in there before I pulled the solder pads on accident repairing a broken pin now im just burning a chip and I use tuner view for data logging because I'm street tuning it.
I am getting a cel code 6 for the ect sensor. I've replaced the sensor and the plug and I've checked the voltage, continuity and resistance on the the wires. Voltage is at 5 volts, no resistance and continuity also checks out. The sensor wasn't being read for the longest time, it was a constant 149.9 degrees Fahrenheit but now,
Tuner view see and reads the engine coolant temp sensor no problem. It's seems actually accurate and the temperature fluctuates as it should like when I'm idling for awhile it'll go up a little but if I'm driving at above 35 mph it goes down to about 189 degrees F. So why am I getting the cell code 6? I've also swapped with a known good ecu and I have the same results.
I've searched already and no one seems to have this problem. Some people did post that had a code 6 yeah but the sensors actually was not working is what I had found. I couldn't find anything similar to my situation at all.
So does anyone have any insite?
Thank you in advanced.
Yes I am doing the reset procedure for the ecu.
Here is my datalog with the ect sensor being read
File Type: csv
Last edited by Thomas Allred; Sep 10, 2022 at 05:16 PM. Reason: Forgot to add information
CPEF9
Sep 11, 2016 02:45 PM
Sloburn
May 19, 2016 10:35 AM
hondaaccordf23
Oct 25, 2012 03:54 PM
blue_hatch
Feb 16, 2011 01:49 PM
dcfour
May 15, 2005 12:26 PM
