FuelTech remote tuners?
Old Nov 8, 2022 | 04:20 AM
Chev's Avatar
Default FuelTech remote tuners?
Wanted to know if anyone knows a good tuner for FuelTech? I'm running a very basic setup and just want to make the car drive able N/A before I go boost.
Thanks!
Old Nov 10, 2022 | 05:54 AM
Chance EG's Avatar
Default Re: FuelTech remote tuners?
Jeff doesn't have Fueltech listed as one of his supported platforms, but I'd still ask him if he'd be available:
https://www.evans-tuning.com/etuning
Old Nov 19, 2022 | 04:48 AM
99pearlude's Avatar
Did you get in touch with them? I need a fueltech tuner as well. I've been working with fueltech tech support but my b18 turns over, but not start. If I give it gas while starting, it will start up but it's very lean. I need some help.
Old Nov 19, 2022 | 04:54 AM
Chev's Avatar
I did, and Jeff told me as of right now he has no plan of tuning on FuelTech. I ended up reaching out to a local tuner and they do. Waiting for them to get me a base map for the moment. I can ask if they can tune remotely if you want.
Old Nov 19, 2022 | 07:22 AM
99pearlude's Avatar
Yeah let me know, I just need the car to start and run, lol. Ill take it in for a dyno tune after the break in miles. Thanks man, and Iook forward and hearing from you.
Old Nov 21, 2022 | 03:37 PM
99pearlude's Avatar
Got it!!!!
https://m.youtube.com/watch?v=uL5GwayORoQ
I had to pull the valve cover and redo the mechanical timing, set the "crank index" to 180 degrees, and used a timing light for ignition timing while turning it over.
cityofcaterpillars
Engine Management and Tuning
Jun 19, 2017 05:09 PM
30psi_gst
Mar 11, 2014 01:10 PM
KyleSJ6033
Jul 12, 2013 06:35 PM
4genaccordfreak
Apr 7, 2013 04:33 PM
j.packsb
Nov 14, 2009 09:13 PM
