D16 ring gaps haven't found a solid answer yet.
Old Jan 16, 2018 | 10:43 AM
Johnoolo's Avatar
Default D16 ring gaps haven't found a solid answer yet.
Back story, going for 300 to 350whp on e85 was thinking a .021 and .024 on ring gaps. .57 ebay turbo. Okay I understand there have been countless threads on ring gaps I'd like to find pre gapped rings, I really don't like the idea of grinding down my rings. The Vitaras I want to purchase for a stock 75mm bore come with NPR rings. What I don' understand is how does the size of the ring compare to ehat the ring gap should be. The NPR rings say the first group of rings size are 1.00 the 2nd are 1.20. is this just the thickness of the ring or say the circumference as far as dnt ring gaps go? thanks a bunch
Old Jan 16, 2018 | 08:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: D16 ring gaps haven't found a solid answer yet.
The 1st and 2nd ring are different thickness. And will vary between piston makes and models.
You have to grind the rings to gap them as every bore is not the same. You can't get "pregapped" rings because of this. Instead you have to custom gap each ring to the bore, just like the machinist will hone each bore to the specific piston. Each piston is not the same and the bore has to be honed custom to the piston for the exact piston to wall clearance.
This is all minute but critical details in engine building.
Boyle.R
Jun 21, 2014 12:38 AM
95blackEG
May 23, 2007 02:50 PM
Muckman
Feb 23, 2007 11:04 PM
97grnrs
Feb 8, 2007 11:22 AM
da6_b17a
Oct 20, 2001 02:02 PM
