ARP bolts on Manley rods
Re: ARP bolts on Manley rods
ARP would be the ones to ask, it's their bolts so they would know the stretch.
The instructions that came with my b18c manley rods said 60 ft lbs with 30 wt oil. I did it in 2 steps, first 30 ft lbs then 60 ft lbs after dipping the bolts in straight 30 wt oil.
Thank you, I’m just doing a bearing check as I had a bad fuel contamination in the oil. Thanks again I didn’t have the torque specs.
