Assistance Needed: How to Degree SK2 Pro 3 camshafts
Old 03-04-2018, 11:14 AM
Default Assistance Needed: How to Degree SK2 Pro 3 camshafts
Here is my setup:
B20v Block -84.5mm Bore
ycp Pistons
Std Rods
Factory Crank
B16a Cylinder Head
S2 Pro Springs and Retainers
S2 Stg. 3 Pro Cams
Works Cam Gears
S2 intake
S90 70mm TB
S2 Fuel Rail
450cc Injectors
GSR Header w/ 2" Exhaust
Does anyone no of any problems with the cams? Also, if anyone is running these, what cam degrees are you running?
TegLK is offline
Old 03-04-2018, 11:16 AM
Default re: Assistance Needed: How to Degree SK2 Pro 3 camshafts
Need HELP badly
TegLK is offline
Old 03-06-2018, 08:55 PM
Default Re: Assistance Needed: How to Degree SK2 Pro 3 camshafts
I don't think you truly understand what "degreeing" a set of cams means... someone else telling you what their cam settings are is like giving you a BASEMAP for your built engine... it still needs to be TUNED for your specific combination of parts. Depending on how different your engine is from theirs dictates how far off those cam settings will be from yours. If you want it RIGHT... pull the engine and degree the cams. Then it will be perfect for your combination.
JRCivic1 is offline
Old 03-07-2018, 01:35 AM
Thanks for the reply ...
my tuner wants me to fix the cams to the car and brg to the dyno.... he told that he will fine tune on the dyno...
I want to know a safe degree to set my cams so I can take my car to him...
TegLK is offline
Old 03-07-2018, 07:30 PM
"Safe" requires checking for piston to valve and valve to valve clearance which you are not prepared to do. So you either need to trailer the car to your tuner or run them straight up at zero, stay out of VTEC and cross your fingers that nothing hits something else.
JRCivic1 is offline
Jdmdctek
03-04-2009 04:18 PM
1QwIkEf
Mid-Atlantic (Sales)
05-04-2007 08:59 PM
1QwIkEf
05-03-2007 07:48 PM
1QwIkEf
Northeast (Sales)
05-03-2007 07:05 PM
Quick Reply: Assistance Needed: How to Degree SK2 Pro 3 camshafts
  • Ask a Question
Question Title:
Description:
