Honda CRV cracked block has an oil leak. How cam I repair?
My oil change at the beginning of the year to replacing the oil sending unit. Now i have a cracked block, what gives and how do I get this fixed without spending thousands of dollars?
Re: Honda CRV cracked block
the good thing is that crv blocks are very cheap. Not sure what year is your crv? hopefully is an older one. You can find a long block from $300-600. The labor is where it will cost you more unless you know how to remove and replace the motor.
