JE 84mm 9.0-1 pistons in ls? Help pleaze
Old 04-15-2018, 04:20 PM
Jm98ek's Avatar
Default JE 84mm 9.0-1 pistons in ls? Help pleaze
Sorry for adding another tread with a uncertain question but I've had no luck searching through the threads and I'm hoping to get an answer asap, found a set of used eagle h beams (part number on side of rod 5394-BN) (not sure if actually eagles or not) and je 84mm 9.0-1 pistons for my build (b18b aiming for 500hp) the part number for the pistons is 302410 and everywhere on the internet says they are for a b18b or b20 with a b16 head or a b18c1 , will they work in my ls build? Thanks for any input
Old 04-15-2018, 08:01 PM
JRCivic1's Avatar
Default Re: JE 84mm 9.0-1 pistons in ls? Help pleaze
If you sleeve it... yes. You cannot bore a stock LS block .120" (3mm) without damaging it.
Old 04-16-2018, 02:51 AM
Jm98ek's Avatar
sorry forgot to mention that, also have darton mid wet sleeves on the way
dcdcdc
03-20-2008 11:28 PM
crxsteve
11-13-2007 04:36 PM
b18bteg14
06-02-2007 01:14 PM
CalvitoSol
08-26-2006 02:43 PM
InfamousRS
10-09-2001 10:05 AM
Quick Reply: JE 84mm 9.0-1 pistons in ls? Help pleaze
