H22 Oil pressure relief valve tension question
Should there be high tension on the oil pressure relief valve spring while tightening the hex bolt.
I had high tension on assembly as if the relief piston was not sat all the way home, although I could hear it topping out on insertion.
Consequently on start-up, litres of oil dumped out on the floor.
From initial inspection it looks to have come from the oil cooler/filter area.
Please advise
Please advise
slammedz6ef
23
02-26-2008 05:47 PM
