H22 thrust washer won't fit
so the thrust washer fits around the crank but the main cap won't fit I fell like I tried everything when I beat on it with a mallet it eats away at the thrust washer I'm getting two new ones can anyone help I've tried to move the crank can u shave them down, is there a small size the standard ? H22a1 with 50 mm mains
Re: H22 thrust washer won't fit
This shouldn't be... can you post pics of how you have installed the thrust shims and the crankshaft ??? Speaking of the crankshaft... is it a genuine Honda stock H22A crank or something else ???
i was told it was balanced and knife edged ill try washers for the 55 main but the 50 main washers fit around the crank fine but were too thick for the main caps
This is why I asked the OP for pictures... the thrust shims are placed on either side of the #4 main journal of the block... the #4 main cap should be placed on top to keep them in place when the crankshaft spins.
i have the motor flipped atm due to cams, but I put it on the left side of the fourth main there was a sport on the crank I saw
Your explanation suggests you only used ONE shim... or TWO stacked on one side... I cannot tell. PICTURE PLEASE !!! The shims should be placed, smooth side facing the block (and beveled and slotted side facing the crankshaft counterweights), on either side of the #4 main journal of the BLOCK. You will see two smooth machined surfaces on the #8 and #9 counterweight of the crankshaft... each facing the #4 main bearing journal.
This picture places the parts in an invisible block sitting right side up as it would be installed in your car. Part #3 is the thrust shims (although they are in fact pictured backwards as installed).
CRANKSHAFT - PISTON for 1993 Honda PRELUDE COUPE
in the picture I see then both comes down I put so on the left side but had one on the bottom and one on top where it looks like a circle
as soon as you said mallet and main cap, I knew this was the case. glad you figured it out. hope you didn't destroy the main cap, block, or crank in the process
deoexmacchina
04-18-2006 08:38 PM
