PR3 Pistons in B18C Type R JDM
Greetings.
I'm going to put the repair size pistons in my B18C Spec98. I ask to give advice on pistons PR3 in this engine. What will be the compression ratio?
Is it necessary to somehow modify the connecting rod or piston?
Thank you in advance and I apologize for my English.
Re: PR3 Pistons in B18C Type R JDM
It all depends on what cylinder head you have there is a honda engine compression calculator I'll post the link. If you an all B18C engine the casting number should be p72 if you have a Type-R head then i believe its p73. Just input the data and it will tell you the compression ratio.
Honda B-Series Compression Calculator by ZealAutowerks
I have the entire engine P73, Type R DC2 JDM. Calculators I tried to count, but they all for some reason show different data. Thank you.
The calculator you propose is from the very beginning. The compression ratio of the factory engine is incorrect.
The calculator says "This calculator is intended for use as a general estimate of your compression only. Not all values are verified. "
Still an easy way to see how compression changes when you use different parts.
I thought it was generally accepted that the JDM ITR engine was half a point higher in compression than the US version... and since the USDM ITR engine has a compression ratio of 10.6:1, that would suggest a JDM ITR compression ratio of 11.1:1 actually. The calculator gets you within a tenth or two...
Can you share with the forum the reason that you need the EXACT compression ratio, and when you find a calculator that provides the data results that meet your expectations, would you please share them here.
Here is the calculator I found, it shows values similar to the truth
Compression Calculator - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedR.com
In this calculator Compression Calculator - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedR.com
Block B18C1/C5
Head B16A/B - B18C5
Piston pr3 (USDM B16A)
Headgasket Thickness OEM B-series 3-layer
Piston-to-Deck Height OEM B18A/B/C1/C5 - B20B/Z
COMPRESSION RATIO 11.11
Block B18C1/C5
Head B16A/B - B18C5
Piston p73-00 (JDM B18C5)
COMPRESSION RATIO 11.10
It's right?
GDD Lonely Krew
Assuming the calculator is off by 2/10ths of a point in compression, what difference would this make to you? It doesnt make a noticeable difference in any way other than the number you are going to tell people so not sure why it is so important to be that exact. If you are looking for exact numbers to the decimal point you should be measuring the compression of your engine, not using a calculator, although again I am not sure what purpose this would serve. Static compression is just a reference point and is not meant to provide any hard data in any way. Dynamic compression is what truly matters in regards to knock (not sure why else you would need to know the compression ratio) but is tough to get numbers on.
As long as you are using factory or OEM style parts in applications that make sense, even a ballpark compression figure should suffice because you are not reinventing the wheel here. If your parts were all custom made and specced differently than the factory pieces then it may be of some value to know the approximate compression ratio..
Aside from hard-parking and telling your bros how you run 13:1 on pump 91 octane in your daily driver, I dont see why you would need to know this figure...
twentyhurtz
11-17-2009 04:58 AM
vtec65
10-18-2003 02:55 PM
