Dyno sheet help
Old Jul 7, 2011 | 07:39 AM
LS/V-T's Avatar
Icon2 Dyno sheet help
First of all I'll let you know I am new to any kind of tuning..
I finally had a chance to get my 9.5:1 2.0l ls vtec (currently naturally aspirated) on a dynojet to see the air/fuel. After adjusting the fuel pressure regulator and adjusting the timing, we got the air/fuel at a comfortable spot.
We have not messed with any actual ecu tuning yet. As far as I know I have a chip burnt on chrome with a p30 basemap upsized to 1.8l.
To me the dyno graph looks pretty crazy..
165.27whp 130.26wtq 104.16 *F humidity 8%
I recently built a nice and solid Ls vtec for boost..
•B18a1 Block
•84.5mm Darton MID Sleeves
•Shaved and Balanced LS Crank 34lbs to 30lbs
•Eagle H Beam Rods / ARP Bolts
•JE Forged Pistons low comp
•GoldenEagle Main Girdle
•ARP Head studs
•P72 GSR Head
•Skunk2 Forged Valves
•Skunk2 Springs / Titaium Retainers
•98 ITR Cams
•GoldenEagle Adjustru Cam Gears
•Edelbrock Victor X Intake Manifold
•Edelbrock 65mm Throttlebody
I am open to any advice you guys can give and I am able to use the dyno jet often free of charge.
Old Jul 7, 2011 | 08:07 AM
mtber's Avatar
Default Re: Dyno sheet help
Do you have a chart that shows air fuel ratios?
Your huge dip at 5500 rpms is because vtec is not set at the correct point..
Old Jul 7, 2011 | 12:15 PM
LS/V-T's Avatar
Before vtec a/f stayed around 13.1 and after vtec it ranged between 13.1-12.8.
Do you have a good idea of where to try a diff vtec point? In about a month I'll have a real tuner here to assist me. I just want to try different things until he comes around.
Old Jul 7, 2011 | 03:15 PM
GagnarTheUnruly's Avatar
Guess where the torque curve for the 2nd cam would hit the torque curve for the 1st cam. Maybe in the 4500-5000 range?
If I were you I'd get a real tune sooner rather than later.
wreckeddc4
22
Sep 25, 2010 03:53 PM
pooorman's type-r
15
Oct 4, 2009 01:36 PM
vtecinmyvains
24
Jul 31, 2009 08:50 AM
killerpenguin21
13
May 20, 2008 10:19 AM
vbherrera
25
Sep 21, 2006 12:05 PM
