LS/vtec basemap vs. PR4 basemap
Old Jul 15, 2011 | 09:28 AM
alperx's Avatar
Default LS/vtec basemap vs. PR4 basemap
hello
When I examine the PR4 basemap, I see that all the ignition timings are more advanced than the GSR basemap, at all RPMs.
I have a LS/VTEC with a comp.ratio of 9:1.
1. For the motor to work more efficiently with pressure below boost, what basemap ignition parameters should I start with do u think ?
2. When the comp. ratio is lower than stock, isn't there more space for advancing the timing more than the stock ?
Old Jul 16, 2011 | 03:20 AM
josephcmiller2's Avatar
Default Re: LS/vtec basemap vs. PR4 basemap
You need to re-think this carefully. When cylinder pressures are lower than stock, there may be more space for advancing timing. If you are boosting, cylinder pressures will be higher than stock. If you are using a lower heat range spark plug (you probably should be if you're boosting) you can't compare apples to apples anyways.
Go with conservative timing values, then get it tuned!
Old Jul 16, 2011 | 05:58 AM
HAMOTORSPORTS's Avatar
Typically, you can run slightly more timing out of boost than with an NA engine, then gradually pull away timing as you reach atmospheric, then retard .75-1.0 degree per psi. of boost pressure (TYPICALLY)
Old Jul 16, 2011 | 10:52 AM
alperx's Avatar
I see..
do you think a GSR map is a good basemap for a LS/VTEC (b18a1+b18c1 head) ?
Old Jul 16, 2011 | 11:26 AM
mouab18c1's Avatar
I'm sure alot of people start off with a Gsr map on a p30 base.
Old Jul 16, 2011 | 12:14 PM
If you are using the stock GSR manifold, then yes a GSR base will be a good start. If using a Skunk2/blox style manifold, use the P30 (B16) base and adjust the fuel multiplier for the 1797 cc. The GSR map is kinda screwy with the timing around 4-6k.
Old Jul 16, 2011 | 01:12 PM
alperx's Avatar
well, actually I use the GSR manifold with the IAB part removed.
so do u think p30 is better to start with ?
I have a neptune on a p28..
p.s. I see that JDM p72 map is much more aggressive than the USDM p72.
can I use the JDM p72 without any problems do u think ?
Old Jul 16, 2011 | 05:16 PM
mouab18c1's Avatar
If you no longer have the Iab then copy the maps from the p72 base and paste it onto the p30.
Old Jul 17, 2011 | 09:53 AM
civickiller's Avatar
my afr was perfect with a gsr map on my lsv, car runs perfect
808DB1
Mar 15, 2008 09:44 AM
BlueShadow
Aug 31, 2005 12:37 PM
LST2
Aug 9, 2005 06:50 AM
DTAYLOR
Aug 15, 2002 08:37 AM
