need basemap for s300
Well i just got hondata s300 and wanted to know if someone could help me by setting me up with a good basemap for my setup. i have a d16y8 with eagle rods, srp pistons(stock compression), stock ports on head with isky valve springs, stock cam, y8 intake manifold, stock tb, omni 4 bar map sensor, rc 750cc injectors, log turbo manifold, turbonetics T3/t4 57 trim .63 a/r turbo, 3 in downpipe, 2.5 exhaust, and 38mm wastegate with 11lbs.
Contact the dealer you bought the system from to see if they can provide you with one.
Otherwise, consider paying for a good basemap from a reputable vendor:
http://www.phearable.net/shoppingcar...ware-c-40.html
i was looking into getting a basemap for you but is your basemap really to to start off of and will it at lease start my car to idle and drive around so i can start tuning it? if the car doesn't start up is there anyway i can email you again and maybe you can tweat the map alittle?
You should have a wideband oxygen sensor gauge to monitor your air fuel ratios before you do anything.
dornon13
Feb 25, 2005 02:23 AM
