Ignitor ICM delete remove, removal, bypass
Old Aug 14, 2011 | 12:06 PM
Max500's Avatar
Default Ignitor ICM delete remove, removal, bypass
Excuse the title, I just did that for search purposes.
A very informative thread, and the reason for my question
https://honda-tech.com/forums/showth...ght=icm&page=2
I am indeed removing the stock ICM and will be using a Mallory 6A Ignition Box with Crane PS92 Coil, running stock ECU (Neptune). Would any of the ignition values need to be adjusted to suit the way the ecu/ignition box fires?
I will be using this circuit
And would I be correct in assuming that this is how I am wiring it up?
Old Aug 14, 2011 | 03:02 PM
THC07's Avatar
Default Re: Ignitor ICM delete remove, removal, bypass
Pretty sure you dont have to change any values w/ neptune
Old Aug 15, 2011 | 08:59 AM
raene's Avatar
A friend of mine did this several years ago and found it to be less reliable than the ICM.
It kept blowing the coils IIRC. Worked great for years without the bypass, hook up the bypass and it killed two coils in a span of months. Went back to stock, no further problems.
Make sure you have a way to get home, good luck with it.
Old Aug 18, 2011 | 01:33 AM
Max500's Avatar
Thanks.
Glove
Mar 18, 2010 07:30 PM
mrdathion
Aug 2, 2007 06:24 AM
bleedblue94
Mar 29, 2005 05:36 PM
miketurbohonda
Nov 28, 2004 07:06 PM
redboost10
Jan 6, 2004 06:23 PM
