s300 syncing time doesnt seem to be right
Old May 25, 2011 | 06:52 PM
bnmm's Avatar
Default s300 syncing time doesnt seem to be right
when i go to disable compensations to put my distributor in time with the computer. first i always thought base timing was 16 degrees not 17 like s300 says and shouldnt my distributor be someone close to the middle? when i put the timing gun on it. i have to turn the distributor almost all the way towards the fire wall to have the light flash in the middle mark on the crank pulley. thanks
Old May 25, 2011 | 07:02 PM
mtber's Avatar
Default Re: s300 syncing time doesnt seem to be right
You can sync the timing to 16 or 18 degrees it doesn't really matter as long as you lock the timing to x value and shoot the distributor timing to x value.
If you are running aftermarket cam gears & your cam timing is not at top dead center you may have to advance the distributor a lot to get 16-18 degrees btdc.
If you are running an aftermarket autozone or napa distributor, get rid of it.
Old May 25, 2011 | 07:05 PM
bnmm's Avatar
no no everything is stock. so as long as i lock s300 i adjust the distributor to match no matter how far its turned?
Old May 27, 2011 | 05:28 AM
mtber's Avatar
In some cases, yes.
Try another distributor assembly if you can to ensure the issue isn't related to the distributor.
MastaFlyMason
Oct 2, 2016 02:53 PM
jdmsleeper12
Nov 8, 2013 06:51 PM
strategy400
Aug 11, 2008 03:49 PM
madmortar
Jun 12, 2008 01:24 AM
lil_kev
Feb 17, 2008 09:08 AM
