hondata update problem help
Old Jul 22, 2011 | 10:28 AM
eg:R's Avatar
Default hondata update problem help
ive just updated my my labtop with the new hondata download and now i cant get connection to the car ecu for datalog. was there something that i did wrong?
Old Jul 22, 2011 | 03:49 PM
mtber's Avatar
Default Re: hondata update problem help
What new version?
The last beta update was 6-13-11 and it works flawlessly.
Old Jul 22, 2011 | 11:18 PM
eg:R's Avatar
I had the s300 software download back in march. When I used my laptop again it pop up that there was a new version. I then download the new version and since then I haven't able to log into my ecu... I try a different USB cable and same thing..
Old Jul 23, 2011 | 07:20 AM
mtber's Avatar
The problem isn't the software.
Does the car start & run?
The only issue is you can't connect to the ecu?
What error do you get when you plug in the usb cable with the engine of, key on?
Old Jul 23, 2011 | 08:53 AM
eg:R's Avatar
The car run fine. The only issue is that I can't connect with engine on or key on. When I plug the USB it doest feel like it's connecting at all. I try a another USB and same thing? It doesn't pop up any error
Old Jul 23, 2011 | 05:37 PM
mtber's Avatar
Try clicking help & update usb drivers in the smanager software.
Old Jul 23, 2011 | 08:35 PM
eg:R's Avatar
k, i try doing that and it pop up error and then it said usb driver updated??
i got the chance to try my buddy laptop and it work find. not sure what happen to my laptop. mine has somthing to do with my usb connection.
Old Jul 24, 2011 | 04:57 PM
mtber's Avatar
Try un-installing the Smanager software & re-installing it with the latest beta version from http://hondata.com/downloads.html
Old Jul 25, 2011 | 11:52 AM
eg:R's Avatar
I try that and sameThing
Old Jul 25, 2011 | 12:59 PM
550whpcivic's Avatar
Are your using the 1.5.4 version? If so uninstall it then download the 1.4.8 then update to the 1.5.4.
Old Jul 26, 2011 | 07:11 PM
eg:R's Avatar
yes i have the new 1.5.4 version, where can i upload the 1.4.8 version at?
Old Aug 14, 2011 | 01:32 PM
hattech's Avatar
what is the erase ecu function available in 1.5.4? anyone here know? is that stable?
THEUSED
Apr 1, 2006 04:08 PM
ebpcivicsi1234
Jan 14, 2005 04:45 PM
qwklude82
Mar 21, 2003 02:09 PM
Smashback
Mar 8, 2003 05:19 AM
