AEM Digital boost gauge install
Old Jun 7, 2011 | 10:34 AM
Bobby_Budds's Avatar
Default AEM Digital boost gauge install
I just ordered the AEM digital boost gauge and I have a question.
The gauge comes with a 3.5 bar map sensor. I have a GM 3 bar map sensor that my tuner installed while tuning. Can I wire the gauge to the current sensor I have installed or will I need to install the sensor that comes with the AEM gauge?
As well if I was to switch to the AEM 3.5 bar sensor can it break my tune?
Sorry if this is in the wrong forum guys but I figured the tuning experts could answer my questions.
Thanks.
Old Jun 7, 2011 | 05:38 PM
MONSTERek4's Avatar
Default Re: AEM Digital boost gauge install
gauge was made to read a 3.5 bar sensor and no u cant just switch map sensor it will need to be retune
Old Jun 7, 2011 | 06:39 PM
mtber's Avatar
Install the sensor that comes with the gauge. Install the gauge per the instructions that came with it.
Old Jun 7, 2011 | 09:25 PM
Thanks for the answer. I will hold off on installing the gauge since the tuner is from the US and I'm in Canada. I'd rather not break my tune.
Old Jun 7, 2011 | 09:32 PM
This may be a dumb question but would there be a way to wire wire in both map sensors? This way I could use the 3 bar solely for the existing setup, and use the aem 3.5 bar strictly for the gauge? Is this possible?
Old Jun 8, 2011 | 06:20 AM
mtber's Avatar
Yes, you simply will have two map sensors on the vehicle.
One for the engine management & one for the gauge.
Old Jun 8, 2011 | 06:21 AM
mtber's Avatar
Google: aem digital boost gauge install
Old Jun 8, 2011 | 06:22 AM
DDTECH's Avatar
Another write up you, you or xeo should do , lol.
Old Jun 8, 2011 | 06:56 AM
mtber's Avatar
http://www.aemelectronics.com/Images...%2030-4406.pdf
dylspil
Mar 7, 2016 04:26 PM
d16z6Tcrx
Engine Management and Tuning
10
May 1, 2010 01:47 PM
champLSinteg
Apr 25, 2009 05:39 PM
2SLO
Nov 9, 2008 05:25 PM
