Using Knock Listening Devices
Old Jul 25, 2011 | 04:03 PM
Eyal 951's Avatar
Default Using Knock Listening Devices
I thought this was interesting reading. It's interesting to see how a professional tuner uses knock as tuning tool.
http://www.apexspeedtech.com/using-k...-to-your-motor
Old Jul 25, 2011 | 05:48 PM
josephcmiller2's Avatar
Default Re: Using Knock Listening Devices
You thought wrong. There was no useful information in this article. Unless part 2 comes out with something useful, this one's a dud. I've been looking for a lot more information on professional tuners and det cans, but there's not as much out there as I would like.
Old Jul 27, 2011 | 07:43 AM
welfarepc's Avatar
what do you want to know about using a det can and tuning?
Old Jul 27, 2011 | 08:24 AM
This article mentions that during tuning, one can purposefully cause detonation in a way that is relatively safe in order to find where the line is. Anyone know how that is done or whether that statement is accurate?
Old Jul 27, 2011 | 09:24 AM
mikesrex's Avatar
sounds like the author is saying you can learn what detonation sounds like by letting it happen at a light load instead of during a WOT pass.....
Old Jul 28, 2011 | 07:56 AM
welfarepc's Avatar
thats what i get out of it
basically you want to slowly add timing in, and keep making pulls. sooner or later its going to knock. and sometimes, it will take a long while... sometimes it will stop making power long before it will knock.
but one thing is for sure, if its knocking, bad things are going to happen quick.
so when you hear knock, listen for the RPM/load its knocking at, dial back the timing, and repeat.
doing that PLUS having a dyno can make it a lot easier to dial in the timing maps.
Old Jul 28, 2011 | 08:23 AM
likwidchz's Avatar
From what I was told and witnessed while tuning was pretty interesting. doing pulls on the dyno take a note at the dyno results and notice the upper rpm ranges, if you see waves/fluttering you can increase timing .. It would be nice if I had examples of this but I don't on hand.
Hp should keep gaining as you add timing, then flatten out, then you should hear audible pinging/knock. I do not know what the threshold is between HP flatting out and audible knock... off hand I would have to guess it has to do with compression ratio and rpm...
To be safe you want to find that point at which hp output stops gaining and back it off a bit Just because you cant physically hear the knock/ping/bb's in a can does not mean there isn't any.
You can do this for all rpm ranges not just WOT tuning "the last 3 columns" might manage to pick up some more torque down low.
I manage to run about 31 degrees at WOT on my JDM H22a stock guts inside..
--Aaron
donperry
Engine Management and Tuning
Aug 20, 2017 01:34 PM
flyrod
Oct 7, 2008 09:15 AM
Tinus Tussengas
Jun 17, 2006 03:19 AM
spike
Sep 3, 2004 03:44 AM
swlabhot
Jun 7, 2004 04:45 PM
