TPS issues in smanager
Old Jul 17, 2011 | 07:53 AM
jake1191's Avatar
Default TPS issues in smanager
Just got my car back together. swapped to a 70mm throttle body and used my old known working tps but now in smanager the tps reads 100% at closed throttle and will go up to around 104% at WOT.
Any ideas what could be wrong?
Old Jul 17, 2011 | 08:10 AM
mtber's Avatar
Default Re: TPS issues in smanager
The issue is not related to hondata.
Sounds like your tps is the wrong tps.
Check the voltage at the tps using a multi-meter on the signal wire.
Old Jul 17, 2011 | 08:12 AM
jake1191's Avatar
I had the same tps in the car 4 months ago and it was perfectly fine. Thats why this is so confusing to me. i will check the voltage after work
Old Jul 17, 2011 | 08:24 AM
mtber's Avatar
If that is the case, then you need to pull out the multi-meter and figure out what you messed up :-)
Did you by chance swap the tps & map sensor plugs?
Old Jul 18, 2011 | 06:42 AM
HAMOTORSPORTS's Avatar
Sounds like when you installed the TPS you didn't get the little finger on the backside of the sensor lined up with the slot on the throttle body shaft. This would make it not move as it should and then when the throttle body is fully open it may just slightly touch the tps finger. Sorry, hope this makes sense
crxb16a90
Nov 18, 2009 06:47 PM
chrisff521
Apr 5, 2009 07:26 PM
92prelude23
Jan 26, 2009 05:43 PM
SPOOLINmatt
Feb 2, 2007 08:04 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
