Power Chips?
Old Jul 12, 2011 | 07:42 AM
phirewire's Avatar
Default Power Chips?
While looking at ebay and found a $25 powerchip.
http://cgi.ebay.com/ebaymotors/POWER...Q5fAccessories
Are these even worth the $25? There suppose to add power and Mileage.
Old Jul 12, 2011 | 07:46 AM
ph3ar's Avatar
Default Re: Power Chips?
No. Leave them alone.
Old Jul 12, 2011 | 07:52 AM
1990edsedan's Avatar
Junk...
Old Jul 12, 2011 | 08:01 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I came in here because I was hungry and you were talking about chips... or so I thought...
...the "Power Chip" is typically just a few cent resistor (I am not sure of the value both in currency and resistance) that usually goes inline with the intake air temperature sensor. It tricks the ECU into thinking colder air is coming into the engine so it dumps more fuel.
Bottom line: unless you want lower gas mileage without any other benefits, then stay away from this SCAM!
Old Jul 12, 2011 | 03:08 PM
rpmraper's Avatar
^^^ agree.. just get a good tune, chrome or hondata depending on much cash you got to spend..they make more, just look around..not on fleabay though, unless its a private seller, just search around you can send your ecu off most of the time..
Old Jul 12, 2011 | 03:17 PM
4drEF's Avatar
Keyboard Humorist
^^ you didn't look at the ebay post. It's a little box with two wires on it that operates just like the post above you (the one you are ^^ing at) described.
And you can't send your ECU off to get tuned. You can only send it off to get chipped and then they may load some 'performance tune' that wasn't meant specifically for your engine.
Old Jul 12, 2011 | 05:51 PM
B34SST_M0D3's Avatar
Looks sketchy and 40hp gain? Lets be serious.. Some Racing Chips are legit but all I can see from this (without a proper dyno chart zz) is it sucking in gas and spitting out half assed results. I would look at reviews before you shoot it down though!
Old Jul 21, 2011 | 06:06 AM
MARTINOAC's Avatar
Theres a reason it's $25.00
Old Jul 22, 2011 | 07:09 AM
klutchDb7's Avatar
Helpful hint: Dont shop for performance parts on ebay.
not-a-stang
Mar 25, 2008 04:33 PM
F22dreams
May 14, 2007 05:10 PM
Doubleclutch17
Sep 22, 2004 07:53 PM
Toda RSXS
Nov 14, 2002 04:16 PM
FuzzyGreen
Feb 26, 2002 12:14 PM
