question regarding a few tuning concerns
Old Jun 15, 2011 | 05:07 PM
sh!ft's Avatar
Who the fack changed my title?!
Default question regarding a few tuning concerns
1. even though i am running neptune, and have an aem wideband as well as a greddy, can i still use my stock 02 sensor to monitor my exhaust gases, or is that why the widebands were used? asking this for emissions reasons.
2. can you still run those same emissions if you cancel the o2 the computer looks for and still run vtec? or would that be pointless?
Old Jun 15, 2011 | 05:13 PM
mtber's Avatar
Default Re: question regarding a few tuning concerns
You should use a wideband to monitor your lamda/air fuel ratios
The narrowband o2 sensor can be eliminated without side effects.
Old Jun 15, 2011 | 05:36 PM
sh!ft's Avatar
and the car will still remain under the emissions the p28(assuming thats the ecu being used) has it set at or does the tuning take care of that as well?
Old Jun 15, 2011 | 06:06 PM
xenocron's Avatar
If you eliminate the narrowband and disable the o2 sensor, the answer is no
Old Jun 15, 2011 | 06:40 PM
sh!ft's Avatar
no to what? no vtak when narrowband is disabled?
Old Jun 15, 2011 | 07:29 PM
Gunmetal_B20_Hatch's Avatar
no longer emissions legal. You can still run the 1v output from your wideband(asuming it has one) to your ECU to act as narrowband emulation for closed loop. However, you would still need to disable the O2 sensor/heater in Neptune to stop the CEL.
Old Jun 15, 2011 | 07:40 PM
mtber's Avatar
vtec functioning has nothing to do with o2 feedback.
Old Jun 15, 2011 | 11:34 PM
sh!ft's Avatar
was always guided under the fact that once the o2 went out, the car went into "safe mode" and disabled the vtec.
Old Jun 16, 2011 | 07:50 AM
HRTuning's Avatar
The O2 not functioning causes it to be in open loop. The ECU is already always in open loop during VTEC.
Old Jun 19, 2011 | 10:28 PM
ACTION JACTION's Avatar
Alot of good info in here.
Side question... Whats the most accurate input for wideband use (Neptune). Is it ELD with resistors clipped? Is this most commonly used?
Old Jun 19, 2011 | 10:52 PM
HRTuning's Avatar
ELD with resistors clipped or EGR Lift seems to be the consensus.
Old Jun 19, 2011 | 11:15 PM
sh!ft's Avatar
defined version of "eld" please if any one can answer.
Old Jun 19, 2011 | 11:57 PM
Electronic Load Detector and pin #D10
themorphious
Jun 29, 2006 06:36 PM
redej878
May 22, 2006 12:18 PM
TheHatchHog
Oct 12, 2004 07:18 AM
Btothe3rdDegree
Apr 15, 2004 07:23 PM
