GM 3 Bar issue
Old Jul 27, 2011 | 10:11 PM
BoostR41's Avatar
Default GM 3 Bar issue
For some reason all 3 pins on the plug are getting 12v ground. Nothing seems to be touching or grounding out anywhere. Has anyone else ever had this issue? Hondata is showing 4psi of boost at idle and dumping fuel.
Old Jul 28, 2011 | 09:19 AM
Spunkster's Avatar
Default Re: GM 3 Bar issue
If you miswired the sensor at any time then the sensor is damaged and will have to be replaced.
Old Jul 30, 2011 | 04:37 AM
xenocron's Avatar
Are you seeing a short to ground on every pin of the connector when its plugged into the sensor or when the connector is unplugged but the Key is ON, engine off?
Are you doing a continuity test or trying to measure voltage on each of these pins? make sure the spot you are putting your ground probe is actually a GOOD ground.
boostjunkieee
Aug 9, 2008 08:43 PM
sihatch19
May 28, 2008 09:56 AM
94turboeg
Mar 8, 2007 09:49 AM
StolenTeg
Jan 8, 2005 06:25 PM
Ltech
Feb 6, 2003 12:36 PM
