B18c1 smoking issues
Old Jun 27, 2011 | 03:57 PM
2000EM1will's Avatar
Icon2 B18c1 smoking issues
i have a 2001 B18c1 gsr motor in my EM1. The motor is fully built with following mods:Skunk2 pro2 cams, eagle connecting rods, weisco high comp pistons with 12.5.1 compression ratio, aem adjustable cam gears, full skunk2 valve train, the head has a 5 angle valve job, apr head studs, skunk2 intake manifold, jdm cold air intake, comtech headers, custom 2.5in exhaust catless with a vibrant muffler.*Just hit about 8k miles on it nd started smikng a little, not black but white smoke. Im tuned on hondata s300 but as of rite now i deffinitely need a tune and a minor valve adjustment. Any suggestions or info. on what my problem might be??? Thanks
Old Jun 27, 2011 | 07:07 PM
mtber's Avatar
Default Re: B18c1 smoking issues
Complete a leak down & compression test.
The issue could be valve stem seals, piston rings etc.
Old Jun 28, 2011 | 12:00 PM
thats what i was thinking about doing. take my head to levines machine shop, nd have them put new seals. but do u think i could be smoking because i need a tune, my car only smokes when i take off then its normal
Old Jun 28, 2011 | 02:24 PM
TheShodan's Avatar
Moderator
The tune can't solve mechanical issues. If the car is running too rich, that's one thing. But this issue is strictly mechanical. no programming or tuning can solve your issue.
Old Jun 28, 2011 | 02:40 PM
PandaEj6's Avatar
This is how I remember it...
black smoke=burning too much fuel
blue smoke =burning oil
white smoke =burning coolant
Agustine Reyes
10
Oct 14, 2017 02:02 PM
99em1civicsi
Engine Machining & Assembly
40
May 28, 2016 09:49 AM
StOnErTuNinG
58
Feb 11, 2007 11:28 AM
TGUNNER
May 27, 2004 04:27 AM
Irishweird00
13
Nov 1, 2003 08:34 AM
