Vtec A/F ratio
Old Jul 26, 2011 | 06:01 AM
likwidchz's Avatar
Default Vtec A/F ratio
Hey guys, what air fuel do you tune for under vtec?
General rule of thumb
I'm not planning on taking this to a dyno anytime soon, I just want to fix the massive amount of black smoke that comes out of the tail end of my hatch when its under vtec.. Currently its 12.4:1 under load, when we tuned it 2 years ago we never spent much time playing with AF ratio under vtec I was just told "it should be here for most power" and we didn't do many pulls.
--Aaron
Old Jul 26, 2011 | 06:36 AM
mtber's Avatar
Default Re: Vtec A/F ratio
All motor vehicles: 12.9-13.4:1 (Full Throttle)
Forced Induction Vehicles: 11.2-12.0:1 (Full Throttle)
Partial Throttle/Idle: 15.5:1 (Light Throttle) 14.7-13.6:1 (Partial to Mid Throttle)
There are many small variables involved in targeting your air/fuel ratios, the main idea is to ensure you are not running too rich or lean & making the safest & best power possible due to maintaining a proper amount of fuel to your motor at all times.
Old Jul 26, 2011 | 09:54 AM
likwidchz's Avatar
Ahh good to know,
I'd imagine the window for it making power is a semi wide window before HP starts to fall off on either end of the A/F spectrum right? Ignition timing is probably more critical at those points.
Thanks for the info.
--Aaron
g0tgot
Engine Management and Tuning
Mar 14, 2013 05:17 PM
Hiboost 2.0
Sep 9, 2011 09:25 AM
hooptie157
Mar 4, 2002 10:38 AM
