Tuner advice high boost timing Question
Old Jul 23, 2011 | 01:57 PM
550whpcivic's Avatar
Default Tuner advice high boost timing Question
Yes I know every motors different, but on AVERAGE on 24psi at 18 degrees timing to much for 93 pump gas?
2.0l lsvtec
1200cc injectors
s366 t4 91ar
topmount twinscroll
gsr cams
I tune myself and haven't had a chance to hit the dyno. So far im spanking 500who camaros 400hp sti 450hp civics so I think my tuning is going pretty good. Also my afr is at 11.7
Old Jul 23, 2011 | 02:38 PM
MONSTERek4's Avatar
Default Re: Tuner advice high boost timing Question
18 degrees is a bit excessive if you ask me i usually use 18 degress when im tuning around 12-13 psi but i tune ignition on the conservative side with pump gas
Old Jul 23, 2011 | 02:57 PM
So what do you think I should be around at 24psi
Old Jul 23, 2011 | 05:36 PM
mtber's Avatar
Google: Maximum brake torque
Old Jul 23, 2011 | 08:55 PM
HAMOTORSPORTS's Avatar
haha ... That should keep him reading for a while lol..
Old Jul 24, 2011 | 10:52 AM
I guess I'm retarded or something but I didn't understand any of it lol.
Old Jul 24, 2011 | 02:46 PM
csmith21's Avatar
2.0l lsvtec
1200cc injectors
s366 t4 91ar
topmount twinscroll
gsr cams
What kind of sleeves are you running? Just out of curiosity.
Old Jul 24, 2011 | 03:11 PM
Darton mid's
Old Jul 24, 2011 | 03:13 PM
csmith21's Avatar
Darton mid's
Nice man.
Old Jul 25, 2011 | 03:34 PM
Blown90hatcH's Avatar
As Vega said....time for some reading.
Do some full throttle 3rd gear pulls and shut it down at WOT/Peak RPM and read the plugs.
Old Jul 27, 2011 | 07:47 AM
welfarepc's Avatar
you might be about to get away with 18 degrees on methanol.
but i think on 93 pump you should be starting off a lot lower. maybe even around 6 degrees and start advancing from there, listening for knock, and doing timed runs through the RPM band.
Old Jul 27, 2011 | 08:19 AM
likwidchz's Avatar
I have heard 1 degree of retard per psi of boost * But take everything you hear with a grain of salt... I don't own a boosted car.
So my h22 runs 31 degrees at full throttle, so if I was running 24 psi I would run 7 degrees of timing according to that, but then someone above said they run 6 degrees of timing with only 12-13 psi.... which would make that rule of thumb pretty bad..
Start at a low ignition value like 0 degrees at 24 pounds of boost while a/f is whatever you want it at though the whole rpm range, then start increasing ignition timing until hp plateau's then back it off a bit or run conservative amount of timing and pull a couple degrees to sacrifice hp output.
This is what I would do If I had a boosted engine..I've just been learning tuning on my own for about 3 years fiddling around with my stock H22A.. using Neptune.
--Aaron
Old Jul 30, 2011 | 04:40 AM
xenocron's Avatar
If you are beating the crap out of your car at 24psi and it hasnt grenaded yet...you must have the best pump gas in the country at the gas station you use
Get your car on a dyno
Old Aug 2, 2011 | 06:02 PM
boosted k20's Avatar
take it on the dyno and start tuning ur timing for low boost 1st. set the timing conservative 1st (.75-1* per psi) and start adding timing 2* at a time. Once you stop making power at with more timing, you reached the limit. Back down the timing another 1-2* from where you made the most power to keep it safe. Once u get ur timing right at low boost start increasing boost in increments and add timing. do the same for all your boost levels.
Old Aug 2, 2011 | 06:04 PM
But with that motor setup and turbo on 93 Pump, timing in most of the cars i have done are around the 12-14* mark.
Old Aug 2, 2011 | 06:23 PM
joe b's Avatar
Thats alot of timing regardless of fuel type . I would say low teens to start off and then add .5 decree until you stop making big power gains . This needs to be done on a dyno .
Old Aug 2, 2011 | 06:41 PM
likwidchz's Avatar
Ignore this.
Old Aug 7, 2011 | 07:43 PM
funhouse75's Avatar
Since your runing 1200cc injectors I would recommend e85 and pump tune for lower boost and around town driving.
Old Aug 12, 2011 | 01:43 PM
recliner15's Avatar
thats a great number
for
e85
7rrivera7
Engine Management and Tuning
Dec 13, 2016 04:19 AM
booboo782
Sep 20, 2013 12:05 PM
Bird333
Dec 8, 2006 02:34 PM
all_out_jdm
May 21, 2005 04:23 AM
turbo Si
Feb 1, 2003 03:59 PM
