how much hp do you pick up from adding timing
Old Jun 14, 2011 | 11:03 AM
ashb82's Avatar
Default how much hp do you pick up from adding timing
my car picked up 30 hp from adding 2 deg of timing is that normal on a turbo car. i am on pump gas 93 oct. my car seems to be liking high timing 18 deg made 400hp on 18psi added timing nothing else picked up 30hp with 2 degrees more i stopped there. i just did not want to push any more. also its a f22 with 8.2 to 1 compression.
Old Jun 14, 2011 | 08:09 PM
mtber's Avatar
Default Re: how much hp do you pick up from adding timing
The answer to how much hp do you pick up from adding timing really is dependent to the specific application at hand etc. There is no general rule of thumb that says 2 degrees = x whp etc.
Google Maximum Brake Torque
Also google "det cans"
Old Jun 15, 2011 | 04:21 AM
ashb82's Avatar
i picked up 12wtq.
Old Jun 15, 2011 | 07:44 AM
Turpid Porpoise's Avatar
Originally Posted by ashb82
i picked up 12wtq.
Congratulations, this thread is pointless because everyone's setup is different meaning that they will all respond to different changes in different ways because no 2 set ups are identical.
Old Jun 15, 2011 | 08:08 AM
d112crzy's Avatar
welcome to tuning ash.
F22's like a lot of timing from my experience. you have a lot of room for error, especially with the even lower compression than stock that you have. dont be afraid to give it a little more. learn to read plugs.
a1320honda
Engine Management and Tuning
May 9, 2013 11:28 AM
RNbuilt
Apr 9, 2008 09:17 PM
Timmay
17
Jun 20, 2007 09:55 AM
dornon13
Jul 6, 2006 02:17 PM
cnycivic
Jun 25, 2003 09:44 PM
