rev issue
Old Jul 28, 2011 | 12:48 AM
Eg6_k20's Avatar
Default rev issue
Hey.
Bro I been going insane trying to find out an issue I'm going thru for the past 2months. I been looking at ALL of posted up threads.
° I recently changed my map sensor, that wasn't my issue.
I have an issue with my acceleration. It chokes between 2000-3000 RPM. Acceleration drops down as if it was to turn off. Then it will pick up on acceleration as if it was a delay. It acts up in & out of gears.
Pretty much my acceleration drop back down at 2000-3000 RPM & picks back up & backfires while passing 3000rpm. I can't explain, maybe I can text, email, or call to demonstrate the sounds.
I have done all my work on my car as far as putting the motor in & connecting all accessories. Car turns on & idles perfect & low just the way I like it.
I got a 92 Civic Si hatch.
• full stock 2004 PRB Type-S 6spd swap w/ harness.
• no harness cutting.
Issue is at Part throttle, not full throttle. Check with video, maybe you can make it out. I just had my boy record it real quick but he went all extra on the recording.
Check it out....
http://youtu.be/HUIA1mnoxMI
Old Aug 31, 2011 | 08:50 PM
JDM936's Avatar
Default Re: rev issue
same exact problem i have please help!!!!
Old Aug 31, 2011 | 08:53 PM
Fliptard's Avatar
Check the dizzy, wires, plugs, plug gap. Do you have a Cat.? is it pluged?
Are you getting any codes?
What about the TPS sensor.?
Old Sep 1, 2011 | 05:23 AM
JDM936's Avatar
no codes thrown or cat.
new o2 sensor, tps, map, plugs, plug wires. fuel filter and dizzy cap???
help me please!
Old Sep 1, 2011 | 05:29 AM
JDM936's Avatar
and it ran fine for ever and out of nowhere it happened when i started it one night after it sat for 2 weeks.
HELP!!!
Old Sep 2, 2011 | 05:37 AM
JDM936's Avatar
help please?
Old Sep 2, 2011 | 05:59 PM
Fliptard's Avatar
Try searching for FICV or FITV or something like that. I remember reading about it in a forum but can't find it. Its a Fast Idle something something.
Old Sep 2, 2011 | 08:43 PM
JDM936's Avatar
yeah its the fast idle thermo valve fitv mine is bypassed. :/
Old Sep 7, 2011 | 01:01 PM
JDM936's Avatar
fixed it!
my new tps had a dead spot.
thanks h-t.
Eg6_k20
Feb 22, 2012 05:34 PM
Eg6_k20
Jul 28, 2011 06:04 AM
T-RO
Mar 26, 2006 06:22 PM
trecool44
Mar 12, 2006 05:00 PM
ICUinMYrearview
Jun 22, 2004 05:53 PM
