How common are head gasket issues on these engines?
Just like the title says, I am deciding what generation to look at for a newer civic. I was strictly limiting myself to the 1996-2000, but I really like the 2001-2005 civics. However I heard these D17 engines have headgasket issues.
Is this true?
How common is it? Like at what mileage? Thanks
Is this true?
Sanji
Re: How common are head gasket issues on these engines?
They're fairly common. See here: https://honda-tech.com/forums/honda-civic-2001-2005-78/01-05-civic-cooling-system-q-overheating-fans-inoperable-etc-2889523/
But, that being said, if you maintain the car using Honda fluids, you can get pretty good life out of the factory headgasket.
They're fairly common. See here: https://honda-tech.com/forums/showthread.php?t=2889523
So how long do you think I can get out of a stock one? I like the looks inside and out, but I don't want to have to replace a headgasket every 50k miles.
Sanji
As for how long you can get out of a factory one... well, that's impossible to judge without knowing the complete history of the car. So, I'll answer with an... indeterminate amount of mileage. Can they last over 100k? Yes. Its all down to how well the car was maintained, and what type of driving/surroundings it endured.
I think its a layered metal gasket, if memory serves me right. I've never had to do it on a D17, to be honest.
Sanji
As for changing the gasket, its not too tough. It just takes time.
If you purchase one, I would recommend flushing the heater core separate from the rest of the coolant system. Then, run all new coolant (Honda brand) in the car. That'll help things. Also, be careful when burping. It can take quite a while, and if the front of the car isn't elevated properly, it won't burp properly.
Why do they go bad? Is it a design flaw?
This is actually interesting because ive never heard of bad headgasket problems in D17's. I had my car for 200xxx kms and i know many people locally who have owned them and never have heard of this being a common issue but good to know!
Yeah its interesting that you say that. It's not like the subaru I was looking at that had a whole thread on the head gasket. However I am still a bit nervous to grab one from this vintage for the headgasket reason. I am torn...
Sanji
Typically, its because someone decides to ignore checking their coolant levels... or they replace the coolant with non-Honda coolant. The mixture of non-Honda coolant and Honda coolant can cause blockages (as they sometimes mix and make a gummy fluid that sticks).
I never had any problems with mine either never leaked a drop of coolant or oil the 5 years I had it either!
I've been using Prestone Extended Life prediluted antifreeze/coolant for quite a while now without any issues. Drained the radiator of the old Honda stuff, refilled with Prestone. I'm assuming it was the old (green) Honda coolant since I bought the car used from a Honda dealer and that's what color coolant was in it. (not the newer blue stuff)
I keep a close eye on my radiator for any signs of deposits or buildup on the fins, and so far there hasn't been any.
112k on the original head gasket, for those who may be wondering.
Sanji
So If I do end up getting one, what should I look for in the coolant?
Sanji
Oh okay, that makes more sense now. So its not like they give out from driving it too much, right? Aslong as it is maintained then it should be golden. Right? And if the temperature gets high on the gauge, that's when you know when to start worrying.
The headgasket can last quite a long time, as long as the coolant system is maintained properly.
If you look at your coolant, make sure it is either a bright green-ish color or the new Honda standard pre-mix, which is a aqua blue color. If its muddy, not translucent, or has particles in it... go through a thorough flush of the system, and run all new coolant.
Thanks a lot for all this information. I really appreciate it!
My HG sh*t the bed at around 130k miles. always used honda coolant and did regular maintenance before problems occurred. Yea, it was pricey getting the HG changed out, but other than routine maintenance, it was the first time the car was in the shop since I bought it at 20k miles so I really cant complain too bad.
I wouldnt rule out buying one used, just make sure theres good records of maintenance. 7th gens can be had for under 4g in good condition, so even if you have to put another grand into it for a head gasket, its still a reliable cheap car.
I will have to keep my eye out for both of them. Thanks though.
timing belt is definitely a PITA on civics, but the same can be said for just about any car, so again, wouldnt rule anything out based on that
