Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
em2 problems pleasee help
Old Jan 25, 2012 | 08:50 PM
lucas_954's Avatar
Default em2 problems pleasee help
OK well i have 2002 Honda civic coupe with around 95k on the odometer , (d17 headers , exhaust , k&n air filter) well this car has many problems . But the main problem which i have not diagnosed yet is these crazy vibrations/shaking i have bin getting lately when im in nuetreal. When i turn on the ac it shakes even more . the air filter makes a crazy whistling noise when i turn on the ac . (the car has a broken rack n pinion if that helps anything ) . But when i turn on the car its really loud and it shakes like crazy for about a minute and then the loudness goes away but it still shakes . i looked under the car and i saw that the exhaust was shaking around the middle of the car . The air filter and engine also shake . i have also noticed that the mpg and the power of the car have also decreased . any advice ? thanks
Old Jan 26, 2012 | 04:43 AM
toyomatt84's Avatar
Sanji
Default Re: em2 problems pleasee help
The engine vibrations could be coming from worn engine mounts. I would inspect them.
As for your rougher idle, you could have a clogged Idle Air Control Valve (IACV), which would require you to remove the throttle body to clean.
Then, for your poor performance, you'll want to look at several things. The spark plugs are a good place to start.
Old Jan 26, 2012 | 11:42 AM
Belmont's Avatar
Sounds like the engine mounts to me.
jhvr001
Honda CR-V & Element
Aug 10, 2013 08:38 AM
triplefive
Aug 9, 2011 08:19 PM
supertouch
11
Jul 20, 2007 10:19 AM
eug_34
17
Oct 13, 2004 04:22 AM
plum
Jul 26, 2004 06:31 AM
