Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
TPS Problem.
Old May 10, 2012 | 11:40 AM
craiger28's Avatar
Default TPS Problem.
Details: 05 Civic 4 dr. 1.7L Auto.
Got the infamous P0122 CEL TPS voltage code, Checked voltage and ohms at the plug itself and it is ok, the reading from the actually sensor was out of whack so I replaced it with a new one Once I installed it I tried to put the sensor back the same way the old one was on the side of the TB (throttle body) Now I am getting the same CEL p0122.
Help Please?
How do I set the new TPS?
Is this why the code came back again after reseting it?
Old May 13, 2012 | 10:02 PM
It Wasn't Me's Avatar
Default Re: TPS Problem.
How did you go about resetting the ECU?
The problem could be the ECU itself, or simply a connection issue which you'll have to isolate and repair. Usually not fun.
Old Aug 5, 2012 | 09:10 AM
milotype2's Avatar
Wow , I am having the exact same problem. Replaced the tps, calibrated it and cleared the the code. The check engine light went out but came back on within seconds. This thing is kicking my butt! Any help would be great. thanks. 05 civic ex 1.7
Devious951
Sep 18, 2009 05:11 PM
steve0527
Dec 11, 2006 05:53 AM
Forrest Gump 9
Apr 26, 2005 09:05 PM
Catman316
15
Apr 14, 2005 03:31 PM
kagegod
Aug 16, 2004 07:59 PM
