Engine starts for 1 sec, and automatically stops
Hi Honda gurus!
I have a huge problem: Yesterday I was driving home, and on the way the engine just stopped. I was taking the car to a parking lot, and tried to start it. When I start the engine, the engine starts, and after 1 sec it stops automatically. It looks the fuel cannot get to the engine. We measured the pressure of the fuel, but it is okay. The next idea was, that there is a problem with the keys (immobisilator), but I tried to start it with the other factory key, with the same result: The engine start, and after 1 sec it stops. Last idea was to turn off the alarm system, but with the same result.
If anyone has an idea, please help me!
Thank you in advance!!!
Re: Engine starts for 1 sec, and automatically stops
I have the same problem on a 2001 Civic. I have replaced the fuel pump and Cam Sensor.The immobilizer light blinks when you turn ignition on but does not blink when car stalls. I was thinking maybe ignition switch? No codes are coming up when scanned.If it is ignition switch can I replace it or does it have to done at dealer because of immobilizer? Please help dont want to just keep replacing parts.
if u put the gas pedal down a bit and crank the car....can the car stay on? I had this problem and its cuz the ECU needed to relearn the Idle for some odd reason. If the car does crank and engine runs with you playing with the gas pedal, hold it at 3k rpm for ~3-5 min and then turn off the car. The next time you turn the car on it should hold idle . Hope that helped.
If i start the engine, and put the gas pedal down imemdiately, it will go till 2000-2500 rpm, and after the engine stops again. :-( At the service they also told, there can be a problem with the engine control unit... Next week I will take it to an official Honda salon, i hope they can help...
Meanwhile I was taking the car to an official Honda Dealer, and they could fix the problem. I try to describe the solition:
After at the Honda official dealership they checked the car, they find, that there is a small piece of plastic gum at the "tension roller" (at the control belt). That piece of gum was very used and coult not hold normally the spiral -> the control has jumped one, so the engine did not get the correct sign, so stopped. The tension roller was changed, since than car works corretly.
So, the conclusion was, that I was thinking that it was an electronic problem, but it was 100% mechanic one.
Hope I could help to anybody with the same problem!
Most likely.
By the sounds of it, his belt tensioner failed which caused the timing belt to slip/jump timing, so the car wouldn't stay running. After replacing the belt tensioner and resetting the timing, the car works fine. If I'm understanding him correctly.
Thanks for updating your thread with this information!
Hi!
I was thinking of the following accesoires (sorry i dont know the english word):
http://www.autosboltgesztely.hu/imag...20-qtt551a.jpg
Its not my photo, just looking for one on the internet... I hope it helped!
Most likely.
vndsd1
08-04-2009 07:48 AM
charjacq
18
07-02-2002 07:19 PM
