Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Code PO300, 301, 302
Old Jun 11, 2012 | 05:57 PM
jasrams's Avatar
Default Code PO300, 301, 302
Ok techies can you help, had a cam plug seal replacement done and in order to do so I had to move the EGR valve (I drive an 02 civic EX). seeing that i was already in the engine bay i decided to do a change of spark plugs (NGK) and when i was through change the cam plug seal. so i removed the egr changed the cam plug seal then placed it on and connected everything. After this the car drived good then it started to sputter. Today when i started it it idled rough and them started to sputter as if it was going to shut off i had to hold a steady rev in order for it to not shut off. then cam the CEL and i got codes PO300, 301, 302. I checked the injectors they are firing well, checked the spark plug an dcoils those are firing well. could it be an issue of the EGR valve or a matter of timing please help.
Old Jun 11, 2012 | 07:25 PM
Rick hybrid's Avatar
Default Re: Code PO300, 301, 302
Did you clean the block surface and the surface of the egr before reinstalling it?
Did you get a new egr gasket?
While the egr valve was off did you spray it and the block surface passage with some carb cleaner spray to clean the deposits off?
Old Jun 11, 2012 | 07:54 PM
lazlong's Avatar
What's the gap on the cylinder 1 and 2 spark plugs? Just because they're pre-gapped doesn't they're pre-gapped right or weren't screwed up in shipping or packaging.
Old Jun 12, 2012 | 05:13 AM
jasrams's Avatar
ok i took them out to ensure they were gapped properly and they are. I didnt clean the egr didnt even know i should change the gasket could this be the problem should i change the egr?
Old Jun 12, 2012 | 05:49 AM
You can get an egr gasket at a regular autoparts store, you don't have to go to a honda dealer (i went to napa, cost about a 1.00). Also, pick up a can of carb spray to clean the egr and engine block passage, you can also use a small scrapper on both.
Disconnect the battery while you're cleaning to clear the codes.
Old Jun 12, 2012 | 03:12 PM
jasrams's Avatar
ok so i went home took off the egr valve only to realize a piece of metal was keeping the valve open. took it ou and cleaned it up and the car started working fine. thanks a million
buzlink
Honda Fit
Feb 22, 2019 03:30 AM
speed84
Sep 6, 2007 06:33 PM
worktech
Feb 8, 2006 01:04 PM
DC2NING
Jun 23, 2004 02:38 PM
Sivicfied
11
Apr 25, 2003 10:32 AM
