Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car stuck in park
Old 07-09-2012, 11:42 AM
jasrams's Avatar
Default Car stuck in park
Ok so i went in my civic today and lo and behold i had no brake light even though i stepped on the brake and when i itried coming out of park to drive I could not also my horn was not working. checked all the fuse and realise the horn fuse was blown replaced the fuse and everything seemed to work fine. I am asking for suffestions just in case it happens again thanks.
Old 07-09-2012, 01:20 PM
Plead da Fif
It Wasn't Me's Avatar
Default Re: Car stuck in park
Really? What do you think you should do if it blows the same fuse again? Maybeee .. look for a short or a bad connection?
Honestly though, that's about it.
Old 07-10-2012, 09:03 AM
jasrams's Avatar
Just dont see what a horn fuse would do with me being stuck in park
Old 07-10-2012, 12:09 PM
southie's civic's Avatar
the fuse isnt the problem its whats causing the fuse to blow if you can look under ur dash see if any wires are exposed the fuse blew cuz something shorted it out ,.,. having no brake light and the fuse blowing , look and see if the wire near the pedal is crushed against someting ,., if its not a wire shorting to ground then its the the brake switch sensor
Old 07-10-2012, 12:13 PM
HondaGuy8's Avatar
This happend to my car the other day, a 1995 civic. the shift solenod would not engage. I took off the interior pice sorunding the shifter and saw that it was stuck. mine had a lot of dirt and stuff around it. I cleaned it and it starting engage agian so I could shift.
87integra
04-24-2018 09:07 PM
Sic_DA_Nine
Audio / Security / Video
01-07-2007 11:04 AM
NoSwapNoCare
09-28-2006 12:47 PM
ZipTieGUy
12
04-15-2006 01:46 AM
da_twiy
04-26-2005 06:57 AM
Quick Reply: Car stuck in park
