01 Honda Civic Stall when Hot outside
I have an 01 Honda Civic that keeps stalling when hot outside. The check engine light comes on and shows intermittent tdc sensor. I replaced the crankshaft sensor but the car continues to stall on hot days and the same code comes up. What's going on? On cool days it drives great. But on hot days, it stalls and won't excel. The car does not actually shut off however. It just stops excelling. almost like there is a governor on the engine at 10 miles per hour. Iv'e brought it to the shop several times and they can't seem to find the problem. I also had the computer re-flashed and had software updates installed on the computer. What's the next step? Is there another sensor that should be replaced that would trigger the check engine light to come on for the crankshaft sensor? The code is P1361. Thanks
Re: 01 Honda Civic Stall when Hot outside
the cam position sensor had a crack so it had some play, got another one and done. It seemed to heat up then loose almost all power, if I let it cool down for a little it would come again
elliotEk
Honda Civic (2006 - 2015)
07-06-2012 02:50 PM
