Transmission & Drivetrain Gearboxes, Differentials, Clutches
b17 cable trans help!!!!
Old Feb 4, 2014 | 12:47 PM
ghosthatch's Avatar
Default b17 cable trans help!!!!
i have a cable jdm gsr transmission with a damaged speedo sensor. they are extremely hard to find and i dont know what to do at this moment. is there anything that i could do to fix this or do you know where i can find a replacement. any and all help would be greatly appreciated
thank you
Old Feb 5, 2014 | 01:32 AM
m4xwellmurd3r's Avatar
If it makes you feel any better ive been driving my car with the sensor busted like that for 2 years without any issues. Makes it easier to work on tbh.
I guess you could wedge a piece of paper when you put the cable in to wedge it in place
Old Feb 5, 2014 | 04:06 AM
MR.johnson's Avatar
Default Re: b17 cable trans help!!!!
any cable b series one will work.
Old Feb 5, 2014 | 08:04 AM
ghosthatch's Avatar
a piece of paper??? is yours broken that far down to where you cant use the clamp as well?
i read that the ls doesnt fit
Old Feb 5, 2014 | 12:32 PM
MR.johnson's Avatar
ok. well then dont listen to me lol.
Old Feb 5, 2014 | 03:13 PM
ghosthatch's Avatar
does that mean you were just talking out of your *** or it actually doesnt fit and im being stubborn?
Old Feb 5, 2014 | 04:44 PM
94EG8's Avatar
Seagull Management
I'm pretty sure it does, it might need to come from a YS1 (92 - '93) LS though.
Old Feb 5, 2014 | 07:40 PM
They dont have a clamp. They use a pin that slides through the gap where yours broke, and through the groove in the cable. I see plenty that have broken at the slot cut into them.
And im not 100% but I think they all work.
I just looked it up. The 93 gsr has the same part number for the speed sensor as a 90 ls 5 speed.
56500-PR3-010
The 90 autos have a different part number but im almost positive I ripped the sensor im using in my car out of a 90 auto, and I have a 92-93 ls 5speed in my car
Old Feb 6, 2014 | 04:08 AM
MR.johnson's Avatar
im saying it does fit and works, i have interchanged them from cable to hydro and hydro to cable. they all fit the same.
Old Feb 7, 2014 | 05:54 AM
sportsman1539's Avatar
Aren't hydro speed sensors electronic?
Old Feb 7, 2014 | 06:47 AM
94EG8's Avatar
Seagull Management
Yes, but when running a cable trans in a hydro chassis or vice versa it's necessary to swap VSSs.
Old Feb 7, 2014 | 08:24 PM
Exactly my point...use the vss that came with the car or the same type.... in other words a hydro vss will bolt up but not work in a da.... its electronic whereas the da is mechanical
Old Feb 10, 2014 | 04:59 PM
FishaCrx's Avatar
Im willing to bet his ys1 is a cable LS.
Old Feb 21, 2014 | 07:03 PM
ghosthatch's Avatar
note the pictures... they arent the same length. now what?
i sure hope so. thanks, dick
Old Feb 22, 2014 | 02:31 PM
ghosthatch's Avatar
anybody?
Old Feb 25, 2014 | 11:36 AM
ghosthatch's Avatar
immmm stuuuuck. dont know what i should do at this point
Old Feb 26, 2014 | 09:35 PM
ghosthatch's Avatar
nobody eyy?
Old Feb 27, 2014 | 03:45 PM
David @ Synchrotech's Avatar
[QUOTE=ghosthatch;49536299]note the pictures... they arent the same length. now what?
The sensor on the right is a D series cable and the one on the left is a B series Cable. I have a B series cable sensor for you. I will PM a price.
Old Feb 27, 2014 | 10:32 PM
ghosthatch's Avatar
[QUOTE=Synchrotech-Transmissions;49550170]
actually i pulled that straight out of my ys1 ls b series transmission
Old Feb 28, 2014 | 06:26 AM
The sensor with the plastic gear on it is from an L3 88-91 Cable D series. Someone must have installed the wrong one in the B trans at some time.
meseetree
Jun 2, 2006 07:19 AM
EF Two
Oct 20, 2005 05:42 PM
JapJunkie
11
Sep 16, 2004 01:57 PM
