B16 Clutch Bleeder Valve Thread Size!!!???
I need to know the thread size of the clutch bleeder valve on the slave cylinder. If someone could provide the dimensions of the bleeder vave screw, length and thread size that would be great.
I need to find a bolt size to plug it so that I can fit my new header on.
DO IT ON ALL FOURS
Re: B16 Clutch Bleeder Valve Thread Size!!!???
How will you bleed it then? Your best bet would be to just shave off the nipple if you can get away with it. Sounds like a poorly designed header if you can't keep a bleeder screw.
