Transmission & Drivetrain Gearboxes, Differentials, Clutches
interchangeable lsd?
Old Mar 11, 2014 | 02:33 PM
pau-pau1's Avatar
Default interchangeable lsd?
I purchased a jdm type r trans with a 4.7 final drive. It is not lsd. my question is can i install a lsd from a 4.4 final drive?
Old Mar 11, 2014 | 03:46 PM
David @ Synchrotech's Avatar
Default Re: interchangeable lsd?
If it is an OEM 4.7 you can install the OEM ITR LSD from a 4.40. As far as I know only the 98+ JDM ITR with LSD came with the OEM 4.7. Are you sure it's a OEM 4.7? Post some pics and the tooth count from the countershaft and ring gear.
Old Mar 11, 2014 | 06:28 PM
pau-pau1's Avatar
yes i made sure, ive opened it many times there is 67 teeth on the countershaft and 14 tooth on the mainshaft. i KNOW for a fact its a 4.7 but i dont know about being OEM? lol. okay so just making sure a gsr lsd will fit my 4.7 final drive?...
Old Mar 11, 2014 | 07:55 PM
The USDM GSR does not come with LSD and the JDM GSR uses a 14 bolt viscous LSD that will not fit. Look at the open diff in the trans for the casting numbers on the flange. PS1 is the small B16/B18B diff and P80 is the larger B18C GSR diff. If you have the P80 open diff, you can use the 10 bolt ITR OEM LSD.
TravisBiggie
10
Nov 23, 2013 02:51 PM
jdm_23_eg6
Apr 12, 2005 11:55 AM
.jacob
Jul 23, 2003 09:18 AM
