Transmission & Drivetrain Gearboxes, Differentials, Clutches
shift fork question
Old Nov 20, 2013 | 05:47 AM
samples26's Avatar
Default shift fork question
Hey guys looking to get some insight on my clutch woes. So I drive a 94 del sol 1.5 non vtec d15 and I installed a new clutch pressure plate and bearings. Problem is I mated the trans back to the motor and the shift fork seems like its stuck.it will only pull back about half way and I dosent seem like I can get the slave cylinder hooked back up beacuse of it.ive already drop out the trans again and repositioned the tb and fork and still the same.... am I doing somthing wrong?is there a trick to it? Any input would be great so I can get this buttoned back up. thanks
Old Nov 20, 2013 | 08:55 AM
Honda Bull's Avatar
Default Re: shift fork question
How far does the end of the fork (where the slave cylinder pushes it) move? About 1/2"?
Old Nov 20, 2013 | 09:23 AM
samples26's Avatar
I would say about that mabey a inch. It just stops about in the middle and that is moving it to the passenger side
Old Nov 20, 2013 | 01:52 PM
samples26's Avatar
Anyone?
Old Nov 20, 2013 | 06:28 PM
nub's Avatar
nub
By what you descibed it sounds normal. The fork will only move freely by hand until it pushes the throwout bearing into the pressure plate.
You need to put the slave cyl. rod into the fork socket and apply firm pressure to force the slave piston to retact. While holding it in place start one of the bolts.
It's like changing brake pads, you have to push the caliper piston back to allow the new pads to fit over the rotor. The difference is with the slave cyl. the piston dosn't stay deperessed if you release pressure.
Unless I'm not understanding your problem.
Old Nov 20, 2013 | 06:36 PM
samples26's Avatar
Thanks nub ill try that out tonight I just didnt want to jam the slave back in and break it but yea it totally makes sense
Simon Szuba
May 29, 2017 01:46 PM
*del_slow*93
Jun 13, 2011 04:54 PM
the_dxB16
Mar 8, 2009 08:37 AM
Sam1am26
Jul 3, 2005 11:03 PM
solsearching
Oct 10, 2001 04:55 PM
