M2b4 trans.
Hello HT, just like to get some input and help. I'd like to start off by saying I'm not a master mechanic by any means so correct me if I use the wrong terms. Anyways I have an m2b4 trans id like to get rebuilt, and also keep in mind this will not be on a stock long block. Now I'd just like some help in transmission rebuilds, who makes a good rebuild kit that is going to with stand power but not break my bank? Also any info on teammfactorys final drives?
Re: M2b4 trans.
Sychrotech makes awesome parts for trans rebuilds. depending on how much you want to re-build it could get pricy. But they have excellent parts and specialize in Honda trans
Re: M2b4 trans.
Im running a synchrotech carbon syncro set with a mfactory final drive and have had zero issues.. Although im not pushing too much power through it.. You wont be able to use a mfactory final drive with the m2b4 differential.. You would have to find a oem 10 bolt lsd or a aftermarket lsd and also change the top case with a px5 case bacause the m2b4 14 bolt differential is a little wider.. I just bumped a thread with a similar setup..
yungmulacrx
Transmission & Drivetrain
17
01-08-2014 03:47 AM
