Transmission & Drivetrain Gearboxes, Differentials, Clutches
Em1 problems with reverse
Old Oct 25, 2013 | 12:16 PM
JdmRex805's Avatar
Default Em1 problems with reverse
Hey whats up. Having problems with only reverse. 1-5 work perfect and have no issues going in. At times it is difficult to put in reverse so i let off the clutch and press it in, to get it to work. Biggest issue is when i back up car feels like it jumps/skips. It doesn't do it all the time either so not sure what it could be. Tried a new shift linkage and no change. Searched and only saw problems with 5th and reverse since they are together, but not just reverse. Trying to get some ideas to see if its a easy fix. Have no experience working on transmissions but might open this one up if its something i can possibly fix.
Old Oct 25, 2013 | 12:21 PM
EJ1B20Vtec's Avatar
Default Re: Em1 problems with reverse
https://honda-tech.com/forums/transmission-drivetrain-127/difficult-put-reverse-2610799/
Old Oct 25, 2013 | 12:28 PM
JdmRex805's Avatar
Im used it being difficult to put in gear. But when im actually backing up it feels like it gets stuck and skips/jumps hard. Never had this happen, can it be the shift rod like it was mentioned?
Old Oct 25, 2013 | 01:59 PM
EJ1B20Vtec's Avatar
possible, it stated "if" its was low on fluid it could have damage.
Old Oct 27, 2013 | 01:03 PM
JdmRex805's Avatar
ttt
Anyone else have any ideas?
JdmRex805's Avatar
ttt
Old Oct 29, 2013 | 07:18 AM
Emeraldbomber's Avatar
Actuall reverse gear could be chipped or broken. Only one way to find out
Old Nov 4, 2013 | 07:55 AM
94CivicSi's Avatar
I purchased a used tranny that was said to have "no reverse". I never drove with it damaged and neither did the person I bought it from.
When I opened it, several teeth on the reverse gear AND reverse idler were either chipped or sheared off. There are some photos here: https://honda-tech.com/forums/transmission-drivetrain-127/s80-ls-tranny-no-reverse-3139037/
I'm guessing yours may look the same based on your description.
Old Aug 18, 2014 | 01:38 PM
JdmRex805's Avatar
Finally had a chance to open up the tranny. First time opening up a tranny so don't have any experience. From what I see bottom of the reverse idler gear looks bad so i will replace that. Not sure if the 1/2 sleeve and the actual mainshaft needs to be replaced? Issue I had was reverse skipped/jumped but not as bad everytime. No problems with 1-5 but recently noticed 1st having a slight change, almost feeling the same but very minimal while taking off only.
Anything else you might notice from these picture i should look at?
Old Aug 18, 2014 | 07:45 PM
Your reverse idler gear is rounded a bit but take a look at the 1-2 collar. That things rough.
Old Aug 18, 2014 | 07:46 PM
Replace both.
Old Aug 19, 2014 | 09:38 AM
JdmRex805's Avatar
Originally Posted by Emeraldbomber
Replace both.
Ok. So both the reverse idler and 1/2 syncro sleeve. Not sure if you can tell from that picture but what about the reverse gear on the mainshaft?
Old Aug 19, 2014 | 09:45 PM
I cannot tell from the picture.
Old Aug 20, 2014 | 07:33 PM
JdmRex805's Avatar
Looks rounded out to me.. What do you think?
Old Aug 20, 2014 | 10:18 PM
Runnerdown's Avatar
Hard to get a super good look, but from those pics I don't see any glaring major defects. The teeth and sliders always look like that. Put it in reverse and rotate the mainshaft to feel how it turns.
Old Oct 17, 2014 | 08:11 AM
Edgarr1216's Avatar
Hey did you ever fix the problem ?? Im having the same problem with my em1 ..
Old Oct 17, 2014 | 12:45 PM
sportsman1539's Avatar
The 1/2 sleeve always looks that way. Everything looks perfectly normal from the pics. Idk what could cause it to "jump" . I would have to ride in the car to see what you mean. With the transmission together, I would put it in reverse and spin the mainshaft and see if it catches on anything as you spin it
Old Nov 11, 2014 | 10:07 PM
JdmRex805's Avatar
Late post but I did end up fixing the problem. I replaced the reverse idler gear and got a synchrotech 1-2 hardened sleeve. The teeth on the stock 1-2 sleeve looked nothing like the new sleeve. Reverse works fine now
Low2High
May 5, 2012 06:40 AM
twiztid00002
Nov 15, 2007 10:32 AM
Mugensr
Apr 12, 2007 09:56 AM
jtshop
Sep 10, 2004 08:46 PM
mike2016
May 20, 2001 03:03 AM
