j32 swapped eg hatch. help!! not going into reverse
I have a j32 vtec swapped 93 eg hatch cx. 6 speed transmission. Tucked bay. I but I'm having an issue. I am unable to go into reverse. It has a shift kit for the transmission so it can be used in an eg hatch. When I go to put it in reverse is acts like it properly goes into gear correctly. But I start giving it gas the shifter feels like it is being pushed forward (out of gear) and it starts grinding. The car did not do this when I bought it. (I bought is already swapped) What I'm wondering is if the linkages aren't actually engaging the gear fully. Or if my synchronizers shot. This is my first j series swapped vehicle. Any input would be much appreciated. Like I said I'm a noob when it comes to j series swaps. Any help??
Re: j32 swapped eg hatch. help!! not going into reverse
Other then that issue is run and drives fine. Pulls hard. No other issues with any of the other gears. And it just started doing this. I just bought this car a couple days ago.
I recently cleaned the reverse lock out silinoid and reset the spring and ball nut on the front of the tranny. Still not able to get reverse to engage.
IRnIntoPrkedCars
32
10-21-2005 11:57 AM
