Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 EG ac bracket trouble
Old 12-31-2013, 03:18 PM
eghatch07's Avatar
I'm trying to use the stock under frame torque mount on my 94 hatch with my B16. I have a GSR bracket and things aren't wanting to line up at all. Is there a difference in the GSR and B16 ac bracket? Can anyone tell me which bracket I need to use to solve the problem? Thanks
Old 12-31-2013, 04:42 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Default Re: B16 EG ac bracket trouble
You need a ac bracket from a USDM crv or off a delsol vtec with the b16. They are the only two that will fit with a swap in a eg.
Old 01-01-2014, 06:47 PM
eghatch07's Avatar
I appreciate that a lot! Definitely helps me know which direction to steer
Old 01-02-2014, 05:36 PM
Seagull Management
94EG8's Avatar
If it's a B16A and you have power steering you need the Del Sol VTEC bracket, if it's a B16B or any other B-series you can use either the Del Sol or CR-V bracket, you can also use the CR-V bracket on a B16A if you don't have power steering.
Old 01-04-2014, 11:52 PM
eghatch07's Avatar
Thank you. Knew that GSR bracket wasn't right. I wish I could share pics and give a little better idea of what's going on. Newb and haven't figured things out around here yet
EJ6JON
03-26-2010 05:06 AM
Mentat Ghola
02-24-2009 01:47 PM
myronwong
05-15-2007 10:43 PM
jadugartir
08-19-2006 12:30 PM
civic_tuner
04-08-2005 07:36 PM
Quick Reply: B16 EG ac bracket trouble
