Whining noise
Whining noise
the transmission sounds like its going in reverse while moving forward. Doesn't do it parked and revving, only when rolling. It does it in and out of gear.
GSR transmission
Any idea what it can be.
GSR transmission
Re: Whining noise
The grind noise sounds when you are going foward as if you are In reverce. And it gets louder the faster you get. And all I put on it was the LSD. Besides everything els is stock.
Re: Whining noise
Did you make sure the clearances were correct with the Diff bearings when installing. GO over and talk to Synchrotech, they know all on Honda trans.
Re: Whining noise
I have a 2008 Honda Accord,103k miles on it , i get a whining noise when i go in reverse, no transmission work done. I have been reading that's "it's normal" , I'm not so sure , when do I worry.
h0ndaSi
Honda Civic (2006 - 2015)
13
10-30-2012 04:56 PM
cvstrat
10-27-2003 10:01 AM
