Transmission & Drivetrain Gearboxes, Differentials, Clutches
need help please
Old Jan 30, 2015 | 05:55 PM
JDMFREAK86's Avatar
Default need help please
So i was driving the other and was coming to stop and all of a sudden my car locked up like i slammed on the breaks but wasnt even touching the breaks now my car woulnt move and it dies when its suppose to be in neautral. The car is a 1993 honda prelude with the h22a and is a 5speed. Any help would be much appreciated thank you
Old Jan 31, 2015 | 04:47 PM
holmesnmanny's Avatar
Check each wheel that it moves freely.
If all are free its possible your clutch has locked up somehow.
Old Jan 31, 2015 | 04:49 PM
JDMFREAK86's Avatar
Default Re: need help please
Ok thank you ill check them in the morning
Old Feb 2, 2015 | 12:26 PM
JDMFREAK86's Avatar
Ok so i jacked it up and wheels move freely but when its in gear they move freely also so idk what to do next fml lol
Old Feb 2, 2015 | 02:42 PM
93egSLEEPER's Avatar
The car cranks and starts? if the tranny was locked up the wheels shouldn't spin. If the clutch was locked up then when you tried to start the car it should try to turn the tranny. Did it make any noise?
Old Feb 2, 2015 | 02:45 PM
LTCxD2B's Avatar
Take out the inspection plate so u can see the flywheel and see if there is any thing jamming it up and try to turn the motor by hand to ensure all the bolts and thing on the clutch are in working order ... Mine was loose and I could wiggle the flywheel and I saw a couple bolts jammed between the bell housing and the flywheel
Old Feb 2, 2015 | 03:25 PM
It might not be a complete lockup. Just slightly locking it up when the clutch is engaged.
Old Feb 2, 2015 | 03:29 PM
If they move freely then nothing is locked up. Its possible the pressure plate simply gave out. Explain exactly what happens when you start the car, starting with when you start to let off the clutch. Give all scenarios and be detailed, neutral, in gear, giving it gas.... Etc etc
Old Feb 2, 2015 | 03:33 PM
Actually check your linkage first.
Old Feb 2, 2015 | 04:36 PM
JDMFREAK86's Avatar
Yeah the car runs fine no problems there. No there was no noises at all it was driving fine when it happened.
Old Feb 2, 2015 | 04:38 PM
JDMFREAK86's Avatar
When its in neutral it dies and its and a little hard to shift. When i try to take off it just revs up the engine and goes nowhere its really frustrating
Old Feb 2, 2015 | 05:26 PM
JDMFREAK86's Avatar
Also when letting the cluth out right before the car dies it makes some like light grinding noises sounds like in the clutch so its most likely my clutch i hope and not my tranny
Old Feb 2, 2015 | 05:56 PM
definitely just sounds like the pressure plate gave out
Old Feb 2, 2015 | 05:59 PM
JDMFREAK86's Avatar
Yeah it seems like it i hope thats it. Thank you for all the help ill post when i find the exact problem
Old Feb 2, 2015 | 06:00 PM
JDMFREAK86's Avatar
I forgot to put theres still pressure when i push in the clutch peddel idk if that helps any
gooberguy31
Oct 21, 2007 07:16 PM
CHAMPwhteEK
Sep 17, 2007 04:01 PM
civiceg94
72
Jul 10, 2007 09:51 PM
locass316
May 13, 2003 08:53 AM
VintegraGSR96
Apr 21, 2003 11:46 AM
