Trans questions
i thought my car had a b16a1 in it because the person i got it from said that was what was in it, i just now found out that it actually has a d16a1 will the l3 trans i have mount to it or do i still have to find a different one
Here, but in the future try to be more descriptive and search.
84-87 JDM CRX Si/Civic Si "browntop" DOHC ZC, 86-87 JDM Integra "browntop" DOHC ZC, 88-89 JDM Integra "blacktop" DOHC ZC all used the CG transmission same as in the 86-89 Integra D16A1 - has separate cover for 5th gear - uses same intermediate shaft as the 86-89 USDM Integra D16A1 - doesn't bolt right up to any other D-series blocks and has different mounts from 88-91 (picture below)
88-91 JDM CRX Si/Civic Si "blacktop" DOHC ZC uses L3 transmission similar to 88-91 USDM CRX/Civic - uses ZC intermediate shaft (with female outer end) and the larger 90-93 Integra type axles
92-95 JDM Civic "blacktop" DOHC ZC uses transmission similar to 92-95 USDM Civic - uses ZC intermediate shaft (with male outer end) and larger 94-00 Integra type axles - has hydraulic clutch
Since you didn't specify, compare the specific parts you are interested in yourself.
Honda Automotive Parts
