Transmission & Drivetrain Gearboxes, Differentials, Clutches
Mounting a B18 facing front/back
Old Jan 28, 2015 | 08:04 AM
BoberitoBrobert's Avatar
Icon2 Mounting a B18 facing front/back
Hey guys first post so here it goes.
I am thinking of building a mazda b2200 with a boosted b18 just because. Only problem is the engine has to be mounted front to back obviously. Since honda transmissions are cable and not hydro, how would you get the transmission linkage to work? Would you need a cable from the shifter going to a plate and another linkage coming off that plate at 90 degrees going to the transmission? Any suggestions?
Thanks,
Rob
Old Jan 28, 2015 | 10:58 AM
DC4KiD's Avatar
Default Re: Mounting a B18 facing front/back
Um... 94-01 B-Series transaxles are hydro
Old Jan 28, 2015 | 12:42 PM
LTCxD2B's Avatar
Ur gonna need some custom gearing since the b series engines turn counter clock wise
Old Feb 2, 2015 | 07:48 AM
I think that a nissan hardbody rear end would work.
Old Feb 2, 2015 | 09:31 AM
Tyler Dirden's Avatar
I am Jack's...
If left to a manual trans, all you would have to do is flip the rear end over for the reverse rotation correction. Look into transmission adapters. One may not be available per say, though may be made by some specialist.
How about the f to b from the s2000. Can it be used b to f for the s2000 transmission?
Old Feb 2, 2015 | 09:49 AM
LTCxD2B's Avatar
What f to b?
Old Feb 2, 2015 | 10:01 AM
I am Jack's...
Well, H and F the same bell housing.
H to B = F to B
Old Feb 2, 2015 | 10:12 AM
LTCxD2B's Avatar
That f series is for accords not the s2000 ... If it does fit u would need to have the f20c spin in reverse... Or b series in reverse in this case
Tinker219
Dec 14, 2024 05:18 AM
js5590
Honda CR-V & Element
Jan 18, 2016 10:19 AM
White_crex
Jan 15, 2016 11:54 AM
forgotmypassword!(OTT)
Apr 29, 2014 12:55 PM
jdmb16acivic
Jun 18, 2004 01:01 PM
