Transmission & Drivetrain Gearboxes, Differentials, Clutches
ITR HELP!!!
Old Dec 30, 2014 | 11:16 AM
jo dude's Avatar
Default ITR HELP!!!
hey guys i have a eg with a itr swap in it and i got the motor from an engine depot and dropped it in no problem...(at first).
i changed the motor oil, tranny fluid, new shift linkage, new shift bushings, and skunk2 short shifter... the car now after changing the water pump, timing belt, belt tensioner, idles weird after it warms up and sometimes even with my foot fully on the clutch it starts to grab and stalls out
and sometimes it doesnt want to go into gear, but if i shut the engine off anf turn it back on it goes in...
Old Dec 30, 2014 | 01:09 PM
94EG8's Avatar
Seagull Management
Default Re: ITR HELP!!!
Clutch either needs to be bled or the master and/or slave cylinder is leaking and needs to be replaced.
Old Dec 31, 2014 | 10:27 AM
jo dude's Avatar
that's what i was thinking.. but the clutch fluid doesn't look low...and i looked around all the clutch lines and i don't see any brake fluid..
Old Dec 31, 2014 | 06:04 PM
94EG8's Avatar
Seagull Management
Pull the boot back on the slave cylinder and check under the dash where the pushrod goes into the master cylinder. That's where you'll normally see fluid leaking.
Old Jan 2, 2015 | 05:10 AM
jo dude's Avatar
cool thanks man, ima check later today
dragan322
May 27, 2013 07:23 PM
JDM-ish
Jan 20, 2007 05:52 PM
707EF8
Jul 29, 2006 08:09 PM
AustinGT
Jun 22, 2005 03:05 PM
ludelvr
Sep 12, 2003 04:20 AM
