Transmission & Drivetrain Gearboxes, Differentials, Clutches
p0715 honda code
Old Jan 19, 2015 | 11:15 PM
jkiddkilla's Avatar
Default p0715 honda code
I have a 1996 honda accord 2.2l vtec Started a couple weeks ago now won't go into drive at all replaced vehicle speed sensor still won't move I don't believe the tranny is fully out I just don't know why it won't shift auto zone says it's my input shaft speed sensor I don't even what it looks like
Old Jan 20, 2015 | 12:55 AM
slowcivic2k's Avatar
Default Re: p0715 honda code
The input speed sensor can be seen by removing the front right wheel and look at the bottom right of the transmission from the wheel well. Inspect for damage to the connector and the wiring harness. This is an electrical code, which means the wiring, sensor, or the TCM is at fault. It is one of the first 2 based on experience.
Your transmission will stay in limp mode until you correct it. If the car fails to move at all, that is an oil level/filter/pump output problem.
Old Jan 20, 2015 | 12:58 AM
jkiddkilla's Avatar
I change the sensor on the back of the transmission and still nothing will only barely go into reverse
Old Feb 26, 2016 | 09:39 AM
upholstery gio's Avatar
P0715. Just change the oil & Mainshaft speed sensor located near the linear solenoid, then it will shift like new
NanceHonda2001
Jul 16, 2018 09:01 PM
cluda
Nov 24, 2017 02:53 PM
thezafarkhan
May 8, 2017 05:50 AM
roydogg
Aug 9, 2004 01:41 PM
guyuenvy
Apr 30, 2002 09:59 AM
